Zetor 5211 Battery Dead
Tannerlee149
New User
I have a Zetor 5211 and whenever I want to use it it wont start because the battery is dead. We went all through the wiring and traced wires and replaced bad wires and put a battery cut off switch to ensure the battery wouldn't bleed. After that we put a new battery and it worked fine for a month or two but now every time I need to feed I have to jump it off. The problem is that it takes probably 30 mins to jump it because the battery is so big, and once I get it started and let it run I can't stop it because once I kill it I can't start it again without jumping it. I'm temped to sell it but when it starts it works great (besides not having brakes;If y'all have any tips on brake repair that would help) If y'all have any idea why or how it's doing this please help. Thanks!
When i worked in town there was a coustomer that had the same problem. he brought the tractor in and i found that the battery cables were up side down i turned them over and it worked fine after that.
