Rumley 6 starter and ring gear
dnd
I would like to put a starter and ring gear on my Rumley 6. It has the hole in the casting for the starter to fit into and the flywheel has the groove for the ring gear. Finally got the fall work done in Wisconsin as the corn and beans would not dry down.
Can anyone help or lead me in a direction here!
Thank you. I understand they were supplied with Waukesha engine model number of 6MZ. Apperantly these engine were also used in trucks?
Question is if anyone has an idea where to search for that.
They offered a rumley six in electric start. A lot of now parts are still around if you look hard enough.
I would check with Mark at jobbersinc.com
He has a huge inventory of NOS Waukesha parts and has been very helpful to me in my past inquiries.
Just noticed your post (haven't been in site for awhile)...
If still looking for starter info start with Wauk Eng Hist Soc (wehs.net)...with engine model and serial # should be able to tell you part # for ring gear and starter Mfg/model and/or what works if original starter NLA...they have no parts but might make suggestions...
Check your tag carefully---early models had the Wauk 6MK, later changing to 6MZ as mentioned above...
6MK was in various mostly orphan trucks 30-35 or so, 6MZ in a larger number of makes mostly thru 30s, some possibly into 40s...and probably lots of other stuff...
Jobbersinc has been mentioned as having a monumental inventory of parts for obsoletes; there've also been comments that they think very highly of each one...
With sympathy, Bud Tierney
