balsabones
I need to find the technical name for the adjustable bolts, that press on the throw out bearing. There are 3 of them, 1 on each arm. I want to search the web to see if I can buy replacements. My tractor is a TAFE 35di, 1996. John Deere D was kind enough to help me diagnose and find the reason my PTO quit working. The drive hub had sneered off of the PTO disk. The factory had left the 3 slave bolts in the pressure plate after install. The main disc and PTO disc still look hardly worn and the false fly wheels are not burned or worn. I want to replace the disc, throw out bearing and pilot bearing. To replace the whole pressure plate assembly is almost $400 compared to less than $100. I will try to post picture of what I need. Thanks to everyone for a great forum.
