long 610 - adding front end loader
kouvakis1
New User
i have and old long 610 and want to add front end loader. I don't have optional pressure connection shown in manual at figure c.0/27. has any body added hydraulic pump in front of engine. is there another way to power front end loader directly at hydraulic pump on front left side of engine. I am hydraulic novice. price of used optional part with lever? does pto hydraulic pump prohibit pto use of rotary cutter? Bill h.
The pump for the loader mounts in the hole above the PTO shaft on the back,the PTO has to be running to power the pump.The hydraulic pump on the tractor that powers the 3pt
won't put out enough to power a loader.The pump off many Fiat Olivers,Longs and AC tractors will fit your tractor.
