themuleskinner
Hi, first off I would like to thank you guys for all the help so far. I have a Long 445dt 1976 and the 3 point lift arms didnt work properlly. When I would put handle in the up position the lift would raise a couple inches at atime and it would take about a minute for it to be fully raised. I drained some of bad milky fluid out and addef some fresh and it started working good but only for about an hour then it started coming up a couple inches at a time again. So yesterday I drained the hole system cleaned metal filter and added all new fluid. Well now it doesnt work at all but the power steering works fine. Is there somewhere to bleed 3 point lift? Why does power steering work and 3 point dont when they both work off same pump ?
