Hittman1
New User
Acting like clutch is going out, from out of the blue it started acting up and grinding gears! I adjusted the clutch at the pedal and no difference! Wondering if I need to go other way on adjustment?
Looked in my manual, it shows the clutches in front of transmission, I also removed inspection cover, not good! I removed the front loader assembly, split the motor from transmission and I can
see the pressure plate fingers and throw out bearings are BO. I'm currently searching for a complete clutch assembly with bearings for PTO and transmission. Thanks, Larry
The engine clutch is the disk inside the clutch pack the PTO disk is on the flywheel.You can find a complete clutch pack on ebay,you'll have to buy the PTO disk separate.
Also get the pilot bearing and both throw out bearings.
Thanks, I ordered a complete clutch set along with an alignment tool, should be here in time for the weekend to put the tractor back together, Larry
