TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Blowing oil from dipstick
rrlund
04-21-2017 07:30:48
Only thing I can address would be the dip stick. I'll assume the engine vent tube or breather cap,whichever it has,is plugged. Sounds like excessive blowby,possibly from the rings being partially stuck from sitting. When the pistons go up on compression,it's leaking by in to the bottom end of the engine and that pressure has to go somewhere,so it blows the dipstick out.
The temp gauge issue could possibly be a bad ground wire to the gauge.
Belarus400a
04-22-2017 11:12:06
 Re: Blowing oil from dipstick in reply to rrlund, 04-21-2017 07:30:48
Ok I fixed the oil issues... damn dirt dobbers The shift lever is fixed
Now I'm thinking the clutch is out I tried to adjust the clutch with no luck...
The fingers are bet work where it pushes the throw out bearing... Wonder what it's worth as she sits?
I found a clutch for 997.00 but don't mind spending that money on it but... I never split one before I feel like I could since I'm very mechanically inclined Help me with this if y'all can
John Deere D
04-30-2017 11:15:31
 Re: Blowing oil from dipstick in reply to Belarus400a, 04-22-2017 11:12:06
Split tractor as per picture:
I had Tractor below monorail:
Tractor split easily:
I had to turn PTO Shaft to align splines with clutch on assembly:
Bob..
rrlund
04-22-2017 11:32:19
What's the issue with the clutch? Just won't disengage? It could be rusted to the flywheel or the splines.
