Jbritt0101
New User
My long 460 died on me about six months ago. I was raking flat ground and it just shut off almost instantly. I checked the fuel and I had about 2-3 gallons in there but I went ahead and put 5gal of fuel in it but couldn't get it to start so I pushed it 20 yards to where I could work on it. The next time I tried to start it, the starter would not do anything so replaced it and although the tractor turned over, it still would not start. I then replaced both fuel filters, bled the fuel system but wasn't getting fuel to the injectors so I replaced the lift pump this past weekend and I still can't get it to start. It will just turn over and over but acts as if it's not getting compression or something. Also now the new lift pump acts as if it's not getting any pressure and won't pump any fuel whenI pump the lever manually. I checked all the fittings and everything's tight as far as I can tell. Does anyone have any idea what's going on with it? Thanks in advance
