This message is a reply to an archived post by Harry in Ky on August 02, 2016 at 15:16:55.
The original subject was "Belarus 420A power steering problem".
I have a Belarus 420AN that does start and run but will not steer either direction Oil reservoir full.. Can see slight movement in steering linkage, steering wheel will stop and engine slow slightly approximately 1.5 turns both directions and will not turn any further. pump is engaged and 3 point works. when put away some time back it would not turn right but would turn left; however, farmer always complained it would steer much sharper one direction then the other. now linkage will only move slightly when turning either direction. Any suggestions, have almost all books but none mention anything about steering!!!!
