Satoh s650g PTO
NHSATOH88
New User
Does anyone know if there is an easy way to disable the PTO on this tractor? it is currently not going into N and the oil seal leaks when it is spinning. I have no need for PTO, thanks.
Do you mean the PTO lever won't shift out? It should push to the back. I would change out the seal, that's an easy job and cheap. You never know you may want or need the PTO someday.
