Worthington tractor model F5
Dan S (NY)
I picked up this Worthington F5 over the weekend. Not running, but the engine turns over. It would have had 5 (or optional 7) gang mowers mounted to it when in use. Mowers are gone but I got the brackets for them. I need to put a battery tray and air cleaner back in it and rewire everything. This has the 134ci Ford NAA or 600 engine so engine parts aren't a problem. The clutch works, steering is actually pretty tight and the transmission seems to shift good. Production serials numbers run from 575 through 639 so they didn't make very many of these.
