Hart parr magnetos
I am trying to determine which magneto would be correct for a Hart Parr 16-30 tractor. I see no reason why it wouldn't be the same as the 12-24 or the 18-36
The mag used will be a ZU4/2 Bosch. The early 12-24 and 18-36 used this kind until they changed the impulse coupler style coming out of the governor housing. From then on they used a FU4/2 Bosch mag. So, if the 16-30 has not been altered from when it was new you will be looking for a ZU4/2 magneto to be correct without needing to replace the drive shaft coming out of the governor.
