long 1400 5 n 1
mwinkeler
New User
I have a long 5 n 1 backhoe and need to know what type of fluid to put into the hyd system. There is a decal near the hyd tank that says to use type a automatic transmission fluid and i need to know if that is what the hyd system uses. I also checked and i cant find type a in my area and was told that dexron 3 was the fluid that took the place of type a. Can anyone give me the correct info here ?
Thanks
Mark
I'm not sure what model a 5 n 1 is but I have a long 460 that I changed all the hyds and transmission oils to travelers premium utf you
get it at tractor supply, same stuff I run in my ford tractor. I use 90-140 gear oil in the final drives, hopes this helps
