1976 Long 445dt power steering cylinder
Hi does anyone have a power steering cylinder they would sell for this tractor or know where i can get one ? Thanks for all your help so far guys. The Muleskinner sends a thousand thank yous !!!!!
I believe its the power assist cylinder. When i bought the tractor it was rigged with wrong cylinder and a logsplitter valve so i have never seen the original
Um almost done
You'll need to take the steering arm off and move it to the 6 o'clock position when the steering is in the middle of its cycleand its the power assist.From what I see you should be able to bolt on an original power assist steering cylinder and rod assembly and be good to go.
No the ones on my tractors have ball joints on each end and the cylinder goes about 2/3 the way to the steering box and then its connected to a rod that goes the rest of the way
I got the pic off a site that sells long parts so I am not sure if it is right one. Do you think yours will work on mine ? If so I am very interested. Can you send pics ?
Do you have a pic of your steering linkage? It looks like it will work, does yours have a power steering pump and lines? Here is some pixs out of my book it is for a 460. Hope this helps. 4x4
Mine is 27" long. But my power cylinder is not the same as the one on the 4x4
Look like the 4x4 bolt on way in front of where mine bolts on
