Wiring for Leader D
Trying to wire Leader D tractor. I can not find a wiring diagram. It has a on off switch and starter button and solenoid for starter. Positive ground. I have neg to solenoid from there to neg on amp meter. Other post goes to starter. Small post to the starter button, but when I hit starter button I lose voltage, new solenoid, not voltage to energize solenoid to engage starter. What am I doing wrong?
Hal, I had a bad ground cable. I did finally run a ground off the base of solenoid to ground and got it to work. I ran a new ground cable to frame. I am up and running. Thank you for your reply.
