Long 510 with broken piston shaft
aj-ky
New User
I have an issue with a Long 510 tractor that ran out of oil due to a leak over the winter and locked up the motor when taking it out of the barn for the first time this year. I definitely learned my lesson there. Either way, I ended pulling the oil pan off and one of the piston shaft had completely broken off.
I wanted to see what you all thought about the cost that might be involved to get the piston shaft fixed and if there could be other things related to a piston shaft breaking.
Any help would be appreciated. I am assuming that the motor would have to be taken apart completely to repair the broke piston shaft.
Thanks.
I this what you're calling the piston shaft? If's called a connecting rod. You probably need to take the engine to an auto machine shop that rebuilds engines.Hal
Running without oil screws up a whole lot of things in an engine crank,cam,cam bearings and on and on.Check out Import Tractor you can get a new short block from them for around
$3000 you'll easily sink that much into to yours most likely.
Yeah, that is what I was referring too. I wasn't sure of the exact name.
Thanks for all the replies.
