I'm getting some crud in the main jet and the tractor bogs down. It will idle fine and using the choke I can get it to run more or less normally, except the throttle lever isn't really doing anything.
New fuel filter and cleaned inlet screen. Cleaned the carb yesterday and used the tractor today. It was fine at the start but after half an hour or so it needed the choke to keep it running.
Jim, have you had any trouble with the E10 gas eating the float ? Have you found any replacement floats ?
Thanks
Greg
Thanks
Greg
