moving satoh brake pedals
riverbend
Has anyone successfully repositioned the brake pedals to make room for larger sized boots ? My foot gets trapped between the differential lock and the way the brake pedals lean in. I'm thinking of a little cut and open, but the brake latch is on the left pedal... If so, how did you do it ?
Greg
I crawled under the tractor and saw the brake pedal position is set by two bolts. The solution was to use (2) M8X1.25 bolts that are 3" long.
Greg
