satoh hydraulic pump ?
riverbend
Has anyone found a source for the seal and orings in
the Kayaba GP1 hydraulic pump on a Satoh S560-G ?
Thanks
Greg
For the hydraulic pump ? The guys at our local NAPA already get all sweaty and shaky when I come in...
Greg
There do not appear to be any parts available for the Kayaba GP-1 pumps.
Having said that, the shaft seal is an SKF 4985. The (2) o-rings on the backside of the pump are 17mm ID X 2.5mm cross section. The o-ring under the cover is 60mm ID X 2mm cross section.
Greg
I have used a co named Motion Industries. They deal in bearings and seals. If you can find one near you, Bring the parts to them. Or check out others in your area. I would be surprised if NAPN can't cross them for ya.
