Farmtrac 80 HYD System
Trying to help a friend. Start tractor up Hyd system doesn't work.Control arm gets no results, steering doesn't work.If I raise the lift arms by hand. The steering works but nothing else does. Shut it off and restart. Sometimes it works. Sometimes nothing.No leaks that I can find. Fresh fluid and new filter. Is this tractor worth keeping. Fluid does foam but not that much.
This happens in hot or cold weather.
