V Avery 1950
Just got the V started and the governor will not
work. Are parts available? Does anyone have a
salvage engine with good governor for sale?
Thanks for any help.
Hercules used kind of a common governor for different series of engines. Have you taken the governor off? What is the problem, overspeed?
The engine goes wide open. There is no resistance
on the governor control rod. I have disconnected
the governor and controlled the throttle by hand
and the governor does not respond to any speed
that I run the engine. I suppose there are some
weights on a sliding shaft that are causing the
problem. Have you been inside this governor?
Thanks for the response.
