I just acquired this tractor. Have no clue of year . im guessing 80s. any way where do i check the hydraulic fluid? is this a common sump where it goes to transmission, hydraulics and the rear end. will universal fluid work. Thanks in advance everyone
Common sump. Dipstick to the right of pto select lever near right edge of case, could be covered up dirt etc. Universal trans-hyd fluid is right.
You might find a year on the trans or diff housing or on top of the head. That will at least tell you when that part was poured.
