Deutz 4506 Gear Box Oil?
1130Leo
What Oil should be used in the 4506 Gearbox? I heard a few different comments locally a few weeks ago, now I am thinking I may have put the wrong oil in last year when I changed it. I did have a hard time finding the type of Oil that was listed but thought what I got was close, now I would like to know what others have been using???
As a DEUTZ dealer we used 80 90 gear oil. However Hytran,ht577 or any other gear oil should work. the hyd. oil was 30 wt. non det. oil. You can use any hyd. oil in this system. Also the injection pump is separate lube oil. The pump uses 30 wt. non det. oil.
