TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Silver King won't run unless choke is on
dzc3
01-06-2014 17:32:06
Also check the flow from the tank, open the drain in bottom of carb. the flow should be steady let it run for a little bit. if its not steady take the fuel line lose at Carb make sure you have a steady flow if its good there then problem is in the carb. Next step is to check the needle and seat and float level. These carbs are EASY to rebuild. let us know if this works
