deutz 10006
Anonymous-0
On a 10006 deutz engine with 6000 hrs when working hard ,engine oil is coming out from the top and side of engine. Are these leaks from o-ring seals? Are they easy to fix or is it something else?
Hi
Not done much with those motors other than fuel injectors/pump and a timing case hyd pump years ago. I seem to think there might be tubes with seals round, where the push rods come up from the cam to the heads.
maybe they are leaking or the rocker cover gaskets also.
Regards Robert
