TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Deutz D4006 injector pump
steve-in-ga
09-18-2013 06:15:21
Thanks Dieseltech. I thought the plug on top may be the fill location but was not sure. I remember there was a 4 bolt cover on the left side of the pump down near the bottom. Is that the one you are referring to? Do I have to remove the 4 bolts and cover to check fill?
Dieseltech
09-18-2013 10:15:27
 Re: Deutz D4006 injector pump in reply to steve-in-ga, 09-18-2013 06:15:21
The level plug is threaded into the 4 bolt cover at lower rear of governor. The 4 bolts do not have to come off. After adding oil, wait a bit and remove the plug. Oil should come out if overfull. Let it drain excess out and replace the plug. Overfull will not hurt either.
steve-in-ga
09-18-2013 15:47:59
 Re: Deutz D4006 injector pump in reply to Dieseltech, 09-18-2013 10:15:27
Thanks Dieseltech
