Long 260 C dual clutch aligment tool
I am looking for a clutch algnment tool for a Long
260 C tractor with a dual clutch. The pilot bearing
ID measures .670" ,and first spline is a 10 spline
that measures .955" OD and the second is a 14 spline
that measures 1.570" OD. Thanks
You don't need splines. Find a guy with a lathe and give him the ID of the pilot bearing and the ID of the splines in each plate and have him whip up a simple stepped shaft for you.
The alignment tool (Fiat clutch tool) is inserted just like any other alignment tool, however there is a collar that gos with that tool that you use to set the height of the release levers to. Also if this is a 3 cylinder you also need to set the spacing on those 3 pins. You have a phone number> J.
