lift lever and how does it operate
gary benton
New User
I have a long 445 tractor and I cant figure out how the lift lever works,mine is stuck but it looks like its stuck on a pin and i cant get it to move. Also have some transmisson problems,but that will be for another day. Need help!!!! Thank you
Need help with lift lever operation and hyd.lift lever I cant figure out how it operates and I dont no if it works the lift or not.Has some type of pin in it and dont no how it works.thanks for any help kinda stuck...
Got an e-mail and really didnt realy didnt have any answer or I dont no how to get to it new at this but thanks anyway.
I used to have a 460. I don't know if the 445 is the same, but there should a a plunger rod that is connected to the lift level. This can become stuck. Try spraying the rod with penetrating oil if it is not moving. This may be useless advice if the 445 is different.
Your problem is a steel shaft seized in a brass bushing due to corrosion. The lift quadrant assy will have to be taken apart to correct it.
