Yesterday's Tractor Co.
Shop Now View Cart
Lesser Known Classics Discussion Forum
Re: CAT D4 7U Pony Motor
El Toro
06-30-2013 04:32:52
You should have points and a condenser in your mag. Take a look at your points and see if they're pitted. If they're pitted I would replace them. Rub them with some 320 wet or dry until they're shiny. Mags have magnets in them for creating the hot spark. Touch them with a flat blade screwdriver to see if they have strong magnetism. Your coil on your mag may be getting weak. Find out what your point setting should be. It's probably in the .013-.015" range. If you have to pull that mag make a sketch where the rotor is pointing, then DON'T Move The Engine while the mag is off. To reinstall the mag rotate the rotor shown in your sketch and install it. Hal
