Long 460 hydraulic problem?? Please help
Justin870
New User
I"m fairly new to working on tractors so any info would be greatly appreciated. The 3point lift control is stuck/ won"t move without really forcing it...and if I can get the lever to move even an inch, the three point moves at a normal amount.
Read about the spring under seat that gets stuck. Could that cause the handle to not move??
Had a diff problem last summer with hydraulics not working at all. Changed fluid & filters...fixed that problem.
Corrosion has stuck the control lever shaft to its bushing in the housing. You will have to remove and disassemble the control assy and apply heat to expand the bush to allow the shaft to turn. Remove the shaft and apply never-sieze.
