1974 Jacobsen High Speed Tractor (US NAvy)
David Terry
New User
I have a 1974 Jacobsen Navy High Speed Tractor that I think was used as an aircraft tug. I"m about to start the restoration process but am having trouble finding any technical info such as hydraulic lash up, electrical diagram, all the way down to color Any ideas where I can look?
Since my first post, I discovered that it is a Jacobsen G-10. Which brings up the question where do you get used Jacobsen parts since new probably aren't available.
Jacobson made LOTS of golf course tractors, for
pulling gang mowers. And lots are still around.
There must be a source through Golf Course
equipment dealers.
Ford industrial engine and most likely Ford tranny and rear end. You could check with Jacobsen too. Find the commercial distributor near you and they might have parts or at least a parts book.
Thanks for the tip. I found Ladds in Memphis that is the closest dealer. I"ve also been in contact with the tech guys at Jacobsen in NC. With the serial and model number they can run down some more info.
My dad sold Jake for about 20 years and Toro for about 20 years as well. He got to the point where his customers knew to call him if they had a problem or needed advice with anything to do with turf equipment. He was the factory appointed sales rep. for both companies at one time or another. He set some world wide sales records too.
