Hercules IXB5 Engine parts
I am looking for help on locating engine parts for an Hercules IXB5 engine that is in a LEADER B tractor. I am looking for OIL PAN gasket, AUTOLITE distributor cap and rotor and possible other gaskets down the road.
You can probably get your distributor cap from Borg Warner known as BWD. Call this toll free number and you will need the model number off the old distrubutor. They may also have points, rotor and condenser. Hal
1-800-566-8334
Napa should also have a dist. cap points and condenser for an Autolite diswt. that's where I got it all for N 62 Cont. in my Earthmaster it has an Autolite dist.
GB in MN
NAPA, "Master Gasket Catalog" lists a full set
for Hercules IXB5 as: FS7557S-2. (This should be a
Fel-Pro number) A pan set is not listed separate.
