farmall a brake pedals
Anonymous-0
how is best way to remove left brake pedal off shaft without breaking pedal already have bolt back out much heat
can padel stand a lot of heat
use a gear puller
use a little heat tap off with hammer
thanks
Typical issue. Heat a little, and melt candle wax into the seam, Pretty soon it will start to slide. Also, they can take a lot of heat, but not quite to red-hot on cast material.
