TractorLinks.com
Lesser Known Classics Discussion Forum
jim dandy
jr. bradley
02-05-2013 15:54:58
just bought a 1962 jim dandy tractor. anybody know anything about them
Dave Sherburne NY
02-07-2013 07:27:53
 Re: jim dandy in reply to jr. bradley, 02-05-2013 15:54:58
Well, I have two of them right now. 16" tires on the rear and 8" on the front. one of mine has tandem transmissions the other a single.One has a 12 horse Kohler the other a 14. Both have the larger 6 inch brakes. One has Fox hydraulics the other has a long hand lift lever. The tandem trans,14horse w/hydraulics I bought as a basket case last summer. It had a broken clutch fork so the PO took it apart left it outside for a couple of years and then decided to sell it. There is a Power King Group with lots of members and info. The one in the picture is getting an engine overhaul. Most parts are available for them
jr. bradley
02-07-2013 12:49:48
 Re: jim dandy in reply to Dave Sherburne NY, 02-07-2013 07:27:53
I just bought this one. No pics yet but I'll get some soon. It is a 1962 serial # 9J8711. Do you know how the starter would be put on this tractor?
Dave Sherburne NY
02-07-2013 14:56:18
 Re: jim dandy in reply to jr. bradley, 02-07-2013 12:49:48
It probably had a starter generator on it. The picture shows one on a 1969. It is not the same SG as a cub cadet because it turns in the other direction, which is good because they are easier to find. In later years PK used a Kohler engine with a smaller starter mounted on the side where the coil may be mounted. Check and see if there is a small hole 1 1/2" on the side away from the carb.which the starter shaft may have gone thru to hit the toothed flywheel. It would be right in front of the coil in the picture.
jr. bradley
02-07-2013 16:06:31
 Re: jim dandy in reply to Dave Sherburne NY, 02-07-2013 14:56:18
The engine on mine is a 9 hp Briggs
Dave Sherburne NY
02-07-2013 16:16:17
 Re: jim dandy in reply to jr. bradley, 02-07-2013 16:06:31
I have one with a Briggs, its a rope start. Starts first pull every time. I have no idea how an electric start might fit on it. Better ask the guys on the PK forum I put in my other post.
