I recently purchased an Avery tractor, but I cannot determine what model it may be. This is what I found. The plate where it tells about the serial number is missing, I think. (From what I can find where the serial number plate should be located is the following: 1A-1952 which is stamped in a steel plate.)
On the right side of the engine block on a plate are the following numbers Top Line: 2424380. Second line: 008-006. Nothing else is legible.
Two things the tractor has are hand brakes and a distributor ignition system.
