Long/Oliver/Allis-Chalmers Round Tube Wide Front Rims!
Fleetline
New User
I was wondering if the front rims on a Long 360 with the round tube wide front had a metric measurement or if I could use a 6"x6" bolt pattern rim? The same wide front was used on some of the fiat built Oliver's and Allis'. Thanks!
Once I had a front flat on my Long 360 a long distance from home. Preferred to get it home and then repair the flat. Farmer had three JD fronts (the later models with more than 2 cylinders) on his service truck and loaned me one. Bolted right on the Long, but vastly different offset, wider, larger diameter tire. Drove it home.
