Yesterday's Tractor Co.
Shop Now View Cart
Lesser Known Classics Discussion Forum
Re: centaur kv magneto
El Toro
11-06-2012 06:26:56
They also made a distributor for that tractor. The part number is IGW-4121A made by Autolite. You can convert that mag to a distributor if the points will open and close & by using an auto type coil.
You would need to run battery voltage to a switch
and from the switch to the coil and another wire to your points. You still need the condenser too and disconnect the mag's coil wire to the points. Hal
PS: That distributor is probably scarce.
