TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Long- final drive
Bus Driver
11-05-2012 18:47:59
Found the problem. The final drive housings are the same for both sides, but one is flipped over for the other side, top to bottom. A hole on one side used for the vent and the other hole is used for the sway chain bracket with a stud in the hole rather than a vent. Used just the opposite on the other side. The sway chain stud was loose. The built up crud from the leak hid the source of the leak. Started cleaning it preparing for repairs and found it. 24mm socket solved the problem within moments.
