Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Lesser Known Classics Discussion Forum
Topic: Long- final drive
[Return to Forum]
Bus Driver
10-27-2012 08:22:47
67.213.63.36
My Long 360, purchased new in early 1978, is leaking lube at the right hand final drive. Feeling with my hand, it seems to be at the gasket where the final drive bolts together rather than at the axle shaft. Removing the wheel is necessary for careful inspection and repair. The tire has liquid ballast plus there is a wheel weight. I cannot handle those alone anymore.
Anyone experienced this condition before on this tractor? Can I expect loose bolts on the final drive cover? Damage to the bolts or cover? Looks to me as if the bolts must hold the full stress placed on that side of the rear axle-- which could be quite a lot.
GEOK used to frequent this forum and was quite experienced on these tractors.
Your help is appreciated.
[Reply]   [No Email]
Bus Driver
11-05-2012 18:47:59
66.226.40.31
 Re: Long- final drive in reply to Bus Driver, 10-27-2012 08:22:47
Found the problem. The final drive housings are the same for both sides, but one is flipped over for the other side, top to bottom. A hole on one side used for the vent and the other hole is used for the sway chain bracket with a stud in the hole rather than a vent. Used just the opposite on the other side. The sway chain stud was loose. The built up crud from the leak hid the source of the leak. Started cleaning it preparing for repairs and found it. 24mm socket solved the problem within moments.
[Reply]  [No Email]
gatchelguy
10-29-2012 14:36:07
209.239.106.240
Another leak source could be the stub axel shaft seal. In any case you will need to remove the wheel and any weights and seperate the final drive housing.
[Reply]  [No Email]
Bus Driver
10-30-2012 08:51:25
66.226.40.31
 Re: Long- final drive in reply to gatchelguy, 10-29-2012 14:36:07
When I feel in the area of the shaft with my fingers, there is no lube there. Just along the parting line that the gasket is supposed to seal.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
