hydralic issues
LJORDAN
New User
I have a 300 series belarus diesel with loader, My rear lift will not work and I got the bucket to lift only by running engine at full power and the bucket raised slow .Anyone with information on what may fix problem Thanks
I would install a pressure gauge to see what the max pressure is. You may need to use a braided hydraulic hose. Check your manual if you have one to see what pressure they used. Your pump may need rebuilding. Hal
