TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Earthmaster Hydraulic Pump
patsdeere
04-23-2012 08:04:50
It has no markings other than 1 casting number (which I don't have with me right now). It is a gear pump.
MNGB
04-23-2012 10:39:27
 Re: Earthmaster Hydraulic Pump in reply to patsdeere, 04-23-2012 08:04:50
Pat the Hyd pump is an Adel the Adel numbers are on the CS end 42315-13 (a Garlock 122 or 140 may work) on the outer hand crank side the Adel number is 42315-14 another number I see is 42302-11. Here's a link to a parts print:
http://www.earthmastertractors.com/Technical/HydPump.html
MNGB
04-23-2012 10:41:37
 Re: Earthmaster Hydraulic Pump in reply to MNGB, 04-23-2012 10:39:27
You should be able to go to most any bearing supply and have them measure the ID the OD and the width of the seals an get a replacement.
GB in MN
Gene Davis (Ga.)
04-25-2012 19:17:03
Some years ago, I had the local bearing house gurus translate the seal I.D. and O.D. into a usable set of numbers and they are as follows.
National--471264-- .625 ID X 1.25 OD X .250 thick.
National--470954-- .750 ID X 1.25 OD X .250 thick.
One of these seals is slightly thicker than the OEM seal, but it worked fine and moved the wear groove to a different spot on the shaft.
Hope this answers your question. Thanks for asking this is what the ERT does.
Gene Davis Tennille, Ga.
