Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Long 610 Hyd stopped working--both lift and remotes
Leaky Boot
12-22-2011 13:13:03
Any more ideas on this. Cleaned filter and was pretty clean. Tried and nothing. It's like there is no pump. I removed filter and no oil had even been on it. Still smelled of cleaning solvent. Funny thing was it was not working then started up and worked all day then has not worked since. I will check for blockage in oil supply line but don't see how that could happen. If it was blocked looks like the pump would destroy itself from lack of oil by now as I still use tractor every day or so to load hay with front loader. Pump is quite and cool. Next will remove pump and replace. I see cheap 610 pumps on ebay less than $200. Just wonder why it stopped, then worked perfect again. Not like it has worn out???? LB
Copyright © 1997-2015 Yesterday's Tractor Co.
