TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Gibson D Brake repair
Brew74
11-03-2011 20:12:40
I just completley rebuilt the brake system on our Gibson D. you have to have a press and some time, and we also replace the bearing on the outer end of the axleshaft-housing. We picked the seal out of the bearing and then let all of the ball bearings fall out of the the cage and then axle will then come out of the housing. then press the brake drum off of the axle shaft. the local auto parts store will be able to get the replacement bearings for you as long as you take them the old ones to match up.
rustbucket
11-25-2011 04:55:54
 Re: Gibson D Brake repair in reply to Brew74, 11-03-2011 20:12:40
Brew is right on, I had to torch the bearing out of mine to get the axle out. Make sure your press is fastened down good. When I pressed mine off, it finally came loose when the press reached 45 tons of pressure and that is with heat applied to the casting. Press jumped clear off the floor about four inches and the noise I made. My wife thought I had to be dead. Wear ear plugs. GOOD LUCK
