Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Wisconsin TJD no spark on one cylinder
El Toro
10-25-2011 17:39:58
Here are the gears in your TJD engine. Hal
Floyd KY
10-26-2011 06:19:03
 Re: Wisconsin TJD no spark on one cylinder in reply to El Toro, 10-25-2011 17:39:58
Thanks. That diagram is very useful to me. I don't know what I'll find when I open it up. Apparently, there is a port clogged because the area didn't seem to be getting any oil. Do you think this is the correct gear? Link attached.
The distributor gear appeared to be undamaged.
El Toro
10-26-2011 06:54:33
 Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-26-2011 06:19:03
That gear should have this number on it GB45A2. It looks to be the correct gear. A new gear is $134.00 plus shipping. I would call the seller to see if it has that number on it. You need to check all those gears for wear. They were not getting any oil. Hal
Floyd KY
10-26-2011 07:27:56
 Re: Wisconsin TJD no spark on one cylinder in reply to El Toro, 10-26-2011 06:54:33
I went ahead and ordered the gear from E-bay. I am worried what I'll find when I open it up. All the gears in that area may be damaged.
El Toro
10-26-2011 07:34:33
 Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-26-2011 07:27:56
Figure 35 shows removing the cover over those gears. Hal
Floyd KY
10-26-2011 07:44:03
 Re: Wisconsin TJD no spark on one cylinder in reply to El Toro, 10-26-2011 07:34:33
Since it meshes with crankshaft gear, if the crank is ruined, I guess the engine is beyond repair.
El Toro
10-26-2011 08:26:09
 Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-26-2011 07:44:03
It's going to be costly to repair it. If there's metal particles from the gear teeth you probably need to do a complete teardown. It may be cheaper to buy a replacement engine from smallenginewarehouse. You don't need all that hp on a woodsplitter. I used a 10hp Tecumseh on a splitter I built back in 1982. I just ran it at a fast idle. Hal
