Yesterday's Tractor Co.
Shop Now View Cart
Lesser Known Classics Discussion Forum
Re: Wisconsin TJD no spark on one cylinder
El Toro
10-24-2011 09:56:15
You can get points at this number. Hal
PS: Once you have the new points installed reinstall the cap, plug wires & and coil wire then see if the engine will run ok. Make sure you're getting battery voltage to your coil. With the points open and the ignition switch in the on position you should have battery voltage on both small terminals on the coil. If you're not getting any fire to your plugs with the new points take a cotton swab dipped in alcohol and clean the points. Then see if you have fire to your plugs. I would clean the rotor too.
