| Lesser Known Classics Discussion Forum |
Topic: Re: Wisconsin TJD no spark on one cylinder
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Floyd KY
10-24-2011 08:09:34
166.214.19.82
 Thanks. The cylinders on my TJD do not appear to be synchronized. There are two posts in the distributor cap. My confusion is that there appears to be only one lobe on the distributor cam. I am attaching a picture. I don't understand how this one lobe opens the points 180 degrees apart as would seem to be necessary to fire the cylinders. I know this works because the engine was running fine a week ago. |
| El Toro
10-24-2011 09:15:00
108.40.22.75
Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-24-2011 08:09:34
| Those points appear to be open and they're not setting on the lobe where you would set your point gap which is around .020." That rubbing block appears worn. I would install a new set. Hal |
| Floyd KY
10-24-2011 09:25:23
166.214.19.82
Re: Wisconsin TJD no spark on one cylinder in reply to El Toro, 10-24-2011 09:15:00
| I set the points at .020 on the wide lobe and it didn't start so I tried setting the points at .020 on the "long" lobe between the flats just to see if it worked. That's the reason the points are open. You're correct that the rubbing block is significantly worn and the points need replaced, however, I am getting good fire from one side (the wide lobe opens the points and fires the cylinder). Your advice is good and I'll try to find new points and maybe even a new distributor. Thanks! |
| El Toro
10-24-2011 09:56:15
108.40.22.75
Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-24-2011 09:25:23
| | You can get points at this number. Hal 1-800-245-0711 PS: Once you have the new points installed reinstall the cap, plug wires & and coil wire then see if the engine will run ok. Make sure you're getting battery voltage to your coil. With the points open and the ignition switch in the on position you should have battery voltage on both small terminals on the coil. If you're not getting any fire to your plugs with the new points take a cotton swab dipped in alcohol and clean the points. Then see if you have fire to your plugs. I would clean the rotor too. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
