Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Lesser Known Classics Discussion Forum
Re: Wisconsin TJD no spark on one cylinder
greygoat
10-24-2011 07:47:53
On most 2 cylinder Wisconsin engines, the pistons
go up and down togather...when one is going down
on a power stroke, the other is on an intake stroke. When one is coming up on a compression
stroke, the other is on an exhaust stroke. On these engines, both plugs fire togather, but one
spark is "wasted" This is NOT TRUE OF THE TJD!
The TJD was a late model and the pistons DON'T go
up and down togather, for, as Wisconsin Motors
says,in it's literature,"More balenced operation"
The TJD use a different distributor, or if Mag.
equiped..a different magneto,from Other 2 cyls.
Floyd KY
10-24-2011 08:09:34
 Re: Wisconsin TJD no spark on one cylinder in reply to greygoat, 10-24-2011 07:47:53
Thanks. The cylinders on my TJD do not appear to be synchronized. There are two posts in the distributor cap. My confusion is that there appears to be only one lobe on the distributor cam. I am attaching a picture. I don't understand how this one lobe opens the points 180 degrees apart as would seem to be necessary to fire the cylinders. I know this works because the engine was running fine a week ago.
El Toro
10-24-2011 09:15:00
 Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-24-2011 08:09:34
Those points appear to be open and they're not setting on the lobe where you would set your point gap which is around .020." That rubbing block appears worn. I would install a new set. Hal
Floyd KY
10-24-2011 09:25:23
 Re: Wisconsin TJD no spark on one cylinder in reply to El Toro, 10-24-2011 09:15:00
I set the points at .020 on the wide lobe and it didn't start so I tried setting the points at .020 on the "long" lobe between the flats just to see if it worked. That's the reason the points are open. You're correct that the rubbing block is significantly worn and the points need replaced, however, I am getting good fire from one side (the wide lobe opens the points and fires the cylinder). Your advice is good and I'll try to find new points and maybe even a new distributor. Thanks!
El Toro
10-24-2011 09:56:15
 Re: Wisconsin TJD no spark on one cylinder in reply to Floyd KY, 10-24-2011 09:25:23
You can get points at this number. Hal
1-800-245-0711
PS: Once you have the new points installed reinstall the cap, plug wires & and coil wire then see if the engine will run ok. Make sure you're getting battery voltage to your coil. With the points open and the ignition switch in the on position you should have battery voltage on both small terminals on the coil. If you're not getting any fire to your plugs with the new points take a cotton swab dipped in alcohol and clean the points. Then see if you have fire to your plugs. I would clean the rotor too.
Copyright © 1997-2015 Yesterday's Tractor Co.
