british leyland motor parts
can anybody help me with my engine rebuild? i bought a 1985-87 Long 5N1 backhoe with a spun bearing the crank had been turned once so i bought a new crank & bearings a gasket kit,rings etc now i am having it rebuilt & the engine guy says the pistons are junk the liners are bad , i need a conn.rod & the injector guy said the injectors are junk the problem is nobody has anything aftermarket & the pistons 210.00 each this is only for my house i do not want to put that kind of money in it i am in it for too much now anything will help THANKS JONATHAN
Hi there...
Not sure which engine is in your Long... and from your description of 85-87 it may not be a Leyland engine...
But if it is, then parts can be found... Sometimes A&I carry parts...other times i"ve had to look on ebay... you will need to know the engine type, although by the 80s they used a 4/98 engine (if yours is 4 cylinder). I"ve got parts out of the UK before now with no problems...
Your other option is to look for a used engine from a wreckers yard...
not really sure of the year but it is a 4 cyl 98 engine some guy was trying to get me to wire some money to the UK via western union & he said he would send parts but it sounded to shady for me do you know where or who in the UK may have parts? thanks Jonathan
If you want genuine parts then Charnleys are the place to go... http://www.charnleys.com/
Otherwise try someone one this forum for reliable dealers .... http://leyland.conforums.com/index.cgi?board=general
will have to copy and paste sorry...
