Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Lesser Known Classics Discussion Forum
Topic: Ditch Witch R40
[Return to Forum]
pilot199
08-27-2011 22:15:33
184.46.89.136
I have a '70 model Ditch Witch with a Continental gasoline engine. I use this tractor sporadically down South here on my place & it generally starts & runs well.
Recently, the machine felt like it was running hotter than normal & would eventually kill on its own. Only after letting the tractor cool down for 10 to 20 minutes would it start again & run fine until it would kill again, while feeling like it was very hot. Now our summer has been extremely hot & this temperature thing is based on my past 6 or 7 years of working this tractor as the only guage that works is the oil pressure & it has remained consistent. The oil & coolant levels are ok. The rear main seal does leak more than I'd like but still not severe.The tractor runs good in all other respects.
I'm thinking that it may be a vapor lock problem but & if so why would this start suddenly without any changes to the engine?
Any information would be greatly appreciated. Thanks.
Gary
P.S. Also, does anyone have experience repairing or adjusting the "crowd control" drive mechanism (used for crawl mode) on these old Ditch Witch trenchers? Mine has started chattering when you push the hydraulic control lever forward or aft & I noticed a little slack in the drive chain. Again, any help is appreciated
[Reply]   [No Email]
greygoat
08-29-2011 07:08:09
75.121.142.128
 Re: Ditch Witch R40 in reply to pilot199, 08-27-2011 22:15:33
Does your engine have a magneto, or distributor.
Someone has already suggested and overheated
coil. The same applys to a magneto. Quitting
when hot, but starting again when cooled down
is a "classic" magneto problem.
Magneto coils, points, and condensers are still
readily available, even from Y/T. You don't look
for engine make and model, but rather, Magneto
make and model.
[Reply]  [No Email]
pilot199
08-30-2011 10:18:47
184.46.47.191
 Re: Ditch Witch R40 in reply to greygoat, 08-29-2011 07:08:09
Greygoat, it has a distributor but I appreciate the suggestion.
Gary
[Reply]  [No Email]
El Toro
08-28-2011 17:10:11
108.3.225.100
Have you checked for fire to your plugs? If the fire is weak or no fire your coil is probaby the culprit. It could be a fuel problem if the engine is running lean. Make sure you're getting a full flow of gas from the tank to your carburetor. If the carb has a main adjustment sc/ew you need to open that. Hal
[Reply]  [No Email]
pilot199
08-28-2011 20:54:15
184.46.48.18
 Re: Ditch Witch R40 in reply to El Toro, 08-28-2011 17:10:11
Hal, thank you. I have had some charging problems in the recent past. Maybe that's going on again. I'll check that out.
Appreciate the suggestion.
Gary
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
