Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
360 Long won't move
metterfalcon
07-11-2011 15:16:30
i can put it in any gear with the clutch pressed and without the clutch pressed while its running. it will not move. the PTO still works and will turn when engaged. my clutch still has plenty of pressure when i press it and when it happened, i heard a loud pop, like a hammer hitting a metal plate.
help?
bpinswv
07-23-2011 17:46:54
 Re: 360 Long won't move in reply to metterfalcon, 07-11-2011 15:16:30
Might be time to split tractor and check clutch and the transmission input shaft. Clutch disc may have broke.
MMMarvis
07-23-2011 18:32:33
 Re: 360 Long won't move in reply to bpinswv, 07-23-2011 17:46:54
bpinswv said: (quoted from post at 17:46:54 07/23/11) Might be time to split tractor and check clutch and the transmission input shaft. Clutch disc may have broke.
I would put something on the pto to see if it tries to turn with or with out the clutch. It doesn't take much friction to spin this.
If this is not in gear much should spin in the trans.
Splitting is a good next step, manual twisting of the input shaft tells much. and if parts of the clutch falls out you know
This post was edited by MMMarvis at 18:38:40 07/23/11.
MMMarvis
07-23-2011 15:54:41
Is there a load on the PTO and the clutch works it? if it does then
Pull the top of the trans and see what is broken.
This is unsafe. Always have a spotter.
Put it in hi gear, pop the top on the trany.
Block the wheels, pull the kill and carefully spin the starter and see what doesn't move ?
But this is unsafe. Always have a spotter.
Transmission or rear pinion gear, possibly axles or reducers to wheels
metterfalcon
07-23-2011 16:38:21
 Re: 360 Long won't move in reply to MMMarvis, 07-23-2011 15:54:41
there is no load on the PTO. i can engage and disengage the PTO.
With the tractor running, i can put the gearshift in any gear without pressing the clutch and there is no grinding of gears and tractor does not move.
i've took the top plate off and i don't see any gears or teeth broke, or metal shavings. i can spend the gears by hand with no problem.
metterfalcon
07-22-2011 15:58:18
anyone else have any ideas as to what is the problem?
Pycoed
07-11-2011 16:08:31
 Re: 360 Long won't move in reply to a.w.davis, 07-11-2011 15:16:30
Hi/lo gear lever popped into neutral?
metterfalcon
07-11-2011 18:08:54
 Re: 360 Long won't move in reply to Pycoed, 07-11-2011 16:08:31
Pycoed said: (quoted from post at 16:08:31 07/11/11)
to be honest, it may have but i am not sure where it is. I bought the tractor used from my boss's dad. The only other tractor i've really used is a ford 9N.
and i should correct myself, its a 350, not 360
EDIT, it is a 350 and only has 6 forward and 2 reverse gears.
This post was edited by metterfalcon at 18:55:17 07/11/11.
